beko cooker
  • #47860
    adv
    tryin to find main oven switch for this model dvc5622x is correct model. but not coming up sayin that model exsists. on connect or local supplier? oven wont switch on .no timer on it an no neon comes on ? hinks its switch or am i missing something? 😳
    #294829
    helo_75
    you might wanna try the thermal fuse, running from the neutral on the terminal block to the clock!!!
    #294830
    adv
    Re: beko cooker
    thers not a clocck on it mate 😆
    #294831
    boselecta
    I would still check the micro temp, normally in a brown rubber sleve, go open circuit alot.
    #294832
    adv
    Re: beko cooker
    wer is it? 😆
    #294833
    Re: beko cooker
    On the back of the oven, in a clip – always pays to actaully look.
    adv
    Re: beko cooker
    yeh i no but its a free estimate. and no what youl say . dont do free estimates lol. wud this shut down oven completely? thanks 😆
    #294835
    djohnston
    Re: beko cooker
    take off back and it is usually on the right hand side half way up usuall held on with a metal clip
    #294836
    adv
    Re: beko cooker
    ta 😆
    #294837
    adv
    Re: beko cooker
    thanks guys wasnt a micro temp . wee pot state. open circuit. doesnt tel temp tho and model, doesnt seem to exsists.gona fit belling state hope thatl be ok? its an over heat state. oven temp state regulating ok?
    #294838
    Re: beko cooker
    If you look at mediator on connect, there are scores of models for Beko cookers. Nearest I could find was DVC5522S. Suggest that might be worth a look.
    Mike.
    #294839
    jonnieboy
    Re: beko cooker
    wee tip for you mate bounce the open circuit one shot stat off a hard surface it resets [closes] it works for all one shot type stats discovered this whilst working for hotpoint as i couldnt keep enough stat kits in the van lol 😀
