Beko Cooker cold oven
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Beko Cooker cold oven
  • #7255
    I have a Beko cooker model DVC 6531 with a fan assisted oven every thing works on it apart from the fact the main oven does not get warm, the fan works but no heat. Any suggestions
    #122300
    Dave_Conway
    Re: Beko Cooker cold oven
    It’s pretty certain the fan element will have failed.
    Not a major repair, the element is around £20, if you need help finding a repairer, pop your postcode up as someone here should be able to oblige 😀
    #122301
    Do you ever get a problem with water on the floor after cooking in the small top oven of your cooker. I recently got the same cooker as you and always have puddles of water at the 2 front corners after using the oven. The manual says there may be droplets of water, but not puddles. I don’t know if I’ve got a faulty cooker or if this is a design fault.
    #122302
    clyde
    Are you sure it’s water? any “puddles” i’ve ever found in cookers has been grease! and it aint nice!!!
    Clyde 8)
    #122303
    Definitely water, has done it since I first got it, what you trying to say that I don’t clean my cooker.
    #122304
    Its probably condensation. Is your kitchen really cold? Dont know of a problem on this cooker but MFI had a problem with an oven recently and do a mod kit for it but it will still produce condensation under certain circumstances.
    #122305
    Dave_Conway
    I’ve seen this quite a few times, it’s caused by condensation which all cooking processes will create.
    Could I ask how old the cooker is please ?
    I would also suggest a letter to Beko customer services, you should find the contact details on http://www.beko.co.uk
    #122306
    The cookers only 4 months old. The kitchen can be quite cold because the back doors open a lot for the dog. An engineer has been out and said he can’t find a problem, I’ve called Beko and asked for a replacement cooker and if another one done the same I wanted a different model. Beko have decided to send another engineer, he’s coming on Thursday.
    #122307
    Hi again, eventually got the engineer up to see cooker again, he never even needed to look at it said he would put in a report to Beko saying its excess condensation. I got in touch with Beko and apparently they have a part which they’re sending me then I phone the engineer and he comes out and fits it and that should solve the problem. Dunno why they don’t just put this part in anyway.
