Re: beko csb4606ffs fridge freezer not working, but light do
Have you ever had the Beko recall Modification on your fridge.
Check with Beko if you have not you will need the serial number.
If you have had the modification it will be the electronic timer or the thermostat faulty.
If you have not had the Mod it will be the thermostat or possibly if it has the mechanical timer then it could be the timer and a fire risk.
It could also be the Timer if it has had the mod to an electronic timer.
Bob
