Beko cut out kit d533w
  • #77498
    allan
    Hi all, been out to Beko cooker model D533w which was dead, there are two cut outs one by the grill and one lower down, the one by the grill has been bypassed with piggy back connector and the lower one has failed, there seems to be only one kit listed for this model, it comes with several replacement wires as well am I right in thinking that this will now replace both? Has anyone come across this before?
    Thanks Allan
    #402381
    Andy jones
    Re: Beko cut out kit d533w
    As far as I know it’s the same kit for both, it replaces the thermal fuse style overload so if it has stats you shouldn’t need to replace the wiring as well
    #402382
    allan
    Ok thanks, so you think I will need two kits in that case?
    #402383
    Andy jones
    I would think so. I’ve tried to get just the stat but it’s the only way I could do it
    At least it’s cheap enough 🙂
