Beko – D 2731 FW- help please..
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Beko – D 2731 FW- help please..
  • #20175
    Dean1474
    I have a slimline Beko – D 2731 FW it is 14 mths old and is in a holiday home so is not often used.
    It sounds as though it is stuck on the water emptying cycle,where ever the dial is turned to. 🙁 Can anyone help with this please..
    #186116
    Washman
    Re: Beko – D 2731 FW- help please..
    Base probably full of water, unplug machine then pull machine out and tip backwards about 45deg , have towels handy , as water will probably come out of base.
    Stop using 3 / 4 in 1 tablets and use the correct amount of powder for this type of machine.
    Mike
    #186117
    Dean1474
    Washman wrote:Hi
    Mike
    Thanks Mike, i will give it ago when i am next there..Fingers Crossed….. Cheers 🙂
    (We do use cheap tablets but they are not multi tabs, we use seperate salt & rinse aid (someone warned us about that…. Thanks)
