Beko D 3422FS dishwasher won’t stop filling.
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Beko D 3422FS dishwasher won’t stop filling.
  • #38367
    Checked inlet valve by disconnecting it and it stops. Removed p/sw and checked it, seems fine. Pressure system clear. Checked p/sw by blowing into it whilst m’c filling – made no difference. Timer is conventional electromechanical type, not electronic so doubt fault is there. Anybody had similar? Not found any clues through searching. There’s a stat/ntc? clipped to the base at the front of the tank which measures o/c…. I’m wondering. Any help appreciated.
    Mike.
    #258630
    If you put it on “spin” program, did he do what should??? (spin and after advance to the end)
    If not, perhaps timer motor is out….
    #258631
    Re: Beko D 3422FS dishwasher won’t stop filling.
    Good thinking Baron. I’ll check timer motor when I go back in a few days.
    Mike.
    #258632
    Went back to this today. Checked timer motor and it metered out ok. Re-checked pressure system and switch and now the filling does stop when I operate p/sw by blowing. But in normal operation machine continues to overfill.
    Was scratching my head wondering if p/sw could go out of calibration, when Mr. appears.(Up to this point I had only met Mrs.). He then proceeds to tell me that he had removed the timer to have a look at it as he suspected it (before my 1st visit) and when replacing it was not sure about reading his own wiring diagram as he had not distinguished betwwen black and brown, marking them both ‘B’. 😡 👿 .
    So now I’m looking for a wiring diagram. Did I read somewhere that Connect had them? I can’t seem to find them there.
    Mike.
    #258633
    pup
    baron wrote:If you put it on “spin” program, did he do what should??? (spin and after advance to the end)
    dishwasher with a spin :rolls:
    #258634
    don
    Mike.
    Hi Mike
    Beko service tech website is located in the Repaircare section. Login and password details are included too.
    HTH
    Don
    #258635
    Thanks Don. Do I have to register and pretend I’m interested in working for them :rotfl: then ?
    Mike.
