Beko D/W DSFN 1532B main pump not activating
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Beko D/W DSFN 1532B main pump not activating
Viewing 1 post (of 1 total)
  • #83468
    mackos
    Hi Guys. Glad to sad in 10 mins. Nice easy one I thought water in base found breather pipe off.Rectified that. Put on prog, empties then fills but no wash action, no voltage at motor. So I tried the test prog, I can’t get that to work but what it does do is bring on the drain pump & the wash motor for 2 secs then nothing. So at least I know the wiring & the wash motor is working but not when required. No error code coming up. Any suggestions would be appreciated. Thanks Mack.
