Beko D3422FW D/Washer
  • #38492
    reaper
    Does program but no heat.Heater Ok.Only one thermostat clamped to the bottom of the tub.I assume this is ntc device and its faulty.Are there any more thermostats on this m/c?Clockwork timer and everything easily accessible but first one Ive been to.
    #259090
    roly16
    Re: Beko D3422FW D/Washer
    If the machine is controlled by a mechanical timer it will have a thermostat/thermostats not an ntc thermistor. Dishwasher thermostats are sometimes located inside the door, in which case what you’ve found will be a toc which may have operated as a result of a thermostat or timer fault.
