I’m llooking for the pressure hose coming from the sump to the pressure switch on a Beko D4321FW dishwasher does anybody know part n/o for it thanks JJ
1800861800 looks like the pressure switch hose for a D3421, theres hosing connected to the float switch on most Beko d’washers that you could use to let you away, just cut it to required length.
The hose looks similar to the grey ribbed dispenser to valve hoseshoses on servis waching machines but a lot smaller, it is thicker than normal pressure hose, i’ll have a dig about to see if i can find something cheers JJ
