Beko D531 Thermal Cutout problem
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Beko D531 Thermal Cutout problem
  • #56416
    snagio
    Hi Guys,
    Having a problem with these cookers, had a few where the thermal cutout from main oven has closed circuit, but having a problem in identifying why? the oven seams toregulate its temptrature ok and have a customer where this has happened for second time, they where using the oven and two rings when it’s has gone off again ‘assuming before I look at this it is same thermal cutout’, Have had a few of these ovens and the DC5422 with same fault.
    Can anyone suggest anything to resolve, only other thing is oven thermastat maybe?
    thanks in advance
    #327295
    allan73
    Re: Beko D531 Thermal Cutout problem
    Had quite a few of those TOC’s go down, think they must be c**p !
    #327296
    snagio
    yeah finding same thing, but try and explain to a customer it’s a faulty component 😯
    gotta be a solution, going to change oven thermostat as its the oven TOC that is closed circuit each time, either that or a useless batch of TOCs!?
    #327297
    snagio
    OK hopefully have a solution to this, just got off phone with tech support @Beko and they confirmed they had a faulty batch of these, so looks as if I replaced with another piece of cr*p 😆
    They have however given me a part number that should resolve this issue, the part number is: 4410101001 however it isn’t in stock 😡
    anyone having this problem, it would maybe be worth getting this part to replace!
    #327298
    Seamy
    210110544 is a thermal cut-out thats been fitted to a lot of Beko cookers, its the button type that takes 2 spade cable connections as opposed to the thermal fuse crimped wired type.
    #327299
    allan73
    It’s the button ones Ive had problems with, have they been changed ?
    #327300
    Seamy
    210110544 is available in the shop on here, try putting the part num’ in to search box.
    #327301
    helo_75
    theres a memo from beko about this
    quite a few got out of the factory fitted incorrectly
    some where fitted to the plate, when they should have been hanging down
    thats what beko say anyway
