Beko D533 Thermal cut-out.
Home Forums Trade Technical & Spare Parts Forums Trade Spare Parts Beko D533 Thermal cut-out.
  • #34335
    Twoten
    I am trying to get hold of the main oven thermal cut-out for the above oven.
    Connect are out of stock and Seme say they won’t be able o get one for about 10 weeks (that’s a lot of take-aways).
    Does anyone know of any other suppliers or alternatively does anyone know the temperature rating so I can try and get a thermal fuse to replace the original?
    Thanks,
    Keith.
    #242193
    aqualectric
    Re: Beko D533 Thermal cut-out.
    The Belling one is usually OK for most ovens – 170 degree 2 tag cut out.
    Connect part no:- 5031682014516. Around £5.
    Hope that helps,
    Steve.
    #242194
    Twoten
    The type fitted to the Beko is an in-line thermo-temp connect part number 5045173291270.
    I’m happy using a thermal fuse like Connect 25206 but would like to know the correct rating.
    #242195
    Twoten
    I’m still struggling with this, the original part number is 160100597, I have tried several suppliers including Beko and nobody has them in stock for at least 4 weeks.
    The thermo-temp fitted in the oven had a Red end cap, I know these are colour coded for the temperature, does anyone know what the red ended thermo-temp rating is?
    Thanks.
    #242196
    Red top = 141c
    Twoten
    Thanks Penguin, I’ll order one today.
