Beko dc7110w stopped drying
Home Forums Public Support Forums Help And Support Tumble Dryer Help Forum Beko dc7110w stopped drying
  • #98754
    Gary Hogg
    Hello
    i have replaced the condenser dryer heater assembly and also the anti interference filter but still not drying clothes.
    any ideas?
    #473681
    what was wrong with the element or did you just change it on chance
    Gary Hogg
    It’s quite old so just changed it to be safe. Was covered in dust etc. Then I changed the interference filter after. Not sure element was broken
    #473683
    this can be a number of things including the main board. have had the relays fail occasionally
    does it start and not heat or not start at all ?
    Gary Hogg
    It starts and operates fine other than no heat. In the dryer it gets a little warm but nothing of note
    #473685
    well with the heat there are 2 poss things i can think
    1 you are imagining it and its not heating at all
    2 the lower power element is coming on but the higher one is not
    we need to figure out which
    run the dryer for 5 mins or so and then stop it and put your hand on the back wall inside the drum. if its heating at all this should feel warm
    if its warm then the possiblilty is the board is not turning the main element on. I would now check the relays on the board for bad solder joints
    Gary Hogg
    Defo warm at the back. Warm in the whole drum to an extent. I still have the old element. Could swap back?
    #473687
    Gary Hogg
    I have left it running and then it has just stopped. Says filter or water tank are full, but they are clear.
    #473688
    cant look at the tech on this one Beko site seems to have a server problem
    but i would look at the pump and water sensor. there will be a float or electronic sensor in the water collection tank at the bottom
    before you do this just check the heater thermal cutout
