Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › beko dcrs 68 stopping
- This topic has 14 replies, 3 voices, and was last updated 14 years ago by
slyp98.
April 7, 2012 at 12:40 pm #68826
slyp98
Participanthave a prob with this one i see other posts but no answers to it , will start but only runs for 2 mins , this decreases the more it is restarted , it ran for 2 mins until i put a damo towel in and straight away went down to 20 seconds anyone have info on this model thanx happy chocolate bunnies
April 7, 2012 at 2:34 pm #372885Allsorts
ParticipantRe: beko dcrs 68 stopping
Is it tumbling in both directions?
April 7, 2012 at 4:54 pm #372886slyp98
no just tumbles one way then stops no lights on other than
April 9, 2012 at 9:01 am #372887Allsorts
If you leave it for a few minutes does it then start again tumbling in the same direction?
April 9, 2012 at 1:29 pm #372888slyp98
as far as i remember it did same direction
April 9, 2012 at 1:43 pm #372889Allsorts
Then your pcb needs changing or repairing. You have a relay and/or capacitor gone on the board.
April 9, 2012 at 6:57 pm #372890Galway
check element and sensor inside door?there is a test program on here somewhere
April 11, 2012 at 7:35 pm #372891slyp98
test program runs fine tumbles both ways not in the order specified though it tumbles clockwise fist then anticlockwise , heats, and the sensor has power to it ?
April 12, 2012 at 4:49 pm #372892slyp98
anyone ??
April 14, 2012 at 2:11 pm #372893slyp98
i guess i’ll just order a sensor bar
April 15, 2012 at 10:07 am #372894Galway
did all or half the element come on?if it all came on then i would be looking at the module
April 15, 2012 at 12:46 pm #372895slyp98
originally when i removed the back cover half of it came on then later all of it was on , all i can say for definite is that it was not very hot in there when i was going through the test program
April 15, 2012 at 2:42 pm #372896Galway
if you have a clamp meter you can how much current it is using
in test mode against the element rating.other than that module i would think.maybe ewm miight be able to test it for you and supply one if it is gone.April 15, 2012 at 9:10 pm #372897slyp98
cheers fella ,i just dont understand how it tumbles both ways in test mode ? is it not using the same relay , caps ,doides etc in normal op ? is it because its isolating the operations seperate parts of the program ? yeah i might try emw depending on the price of a new board thanks
September 23, 2012 at 12:19 pm #372898slyp98
all sorted with a new control module , not bad on price either well done beko
