I have a Beko DCU 7230W Condensor Dryer that stopped working. I was hoping it was just the condenser on the main power line but upon opening it up the PCB is burned. A couple of the finer traces leading to relay RL3 are burned up as are a surface mount diode near relay RL1 – both on the control not power side of the relay. Some surface mount caps near connector KN4 are burned and also here is also a hole in the ATMEGA!
I can get a new board. However, are there any multimeter checks I can do to determine if there is a component, like the motor/pump, that blew the PCB? I don’t want to spend £50 on a new PCB and find it blows again if some other part if actually at fault. Any continuity/short/resistance checks I can make before I buy a new PCB?
Thanks very much.
