Hi. Beko condenser dryer no heat. Heater, stat and heater ntc reading ok. ntc is about 29k cold. front ntc below filter about 19k and varies with heat from hand. Tested from pcb connection.Examined pcb for dry joints. got a high reading (1500k) from thin white sensor wires on right of board. dont know if they go to sensors in drum?
put into test mode. can get drum to rotate anti clockwise first press, but other sequence doesnt work as suggested.
dryer doesnt flash any faults, drying light comes on both timed and sensor tried. Does a lot of reversing, 18 second intervals.
dont know anymore,any help appreciated.
