Beko DCU 8320 stops after one min
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Beko DCU 8320 stops after one min
  • #97572
    delta01
    hi i checked all the usual things but no joy does this model have a thermistor and if so where is it located any help appreciated thank john
    #468440
    check model i can find DCU 8230
    does it stop on ther timed programmes as well ?
    delta01
    Hi dave i will ask the customer to try it , what is the possibilty if it does, not thanks John
    #468442
    delta01
    Hi Dave it stays on on timed
    #468443
    that would mean its a sensor problem
    it believes the washing is dry so stops the programme
    if you confirm the model and let me have an email add will see if i can find some tech
    delta01
    Hi Dave its been suggested that it could be a build up of fluff behind the sensor i will try that thanks
    #468445
    delta01
    Hi removing the sensor was difficult i got all four screws out but it resisted i could not get it fully off but some fluff came out and it seems to be ok thanks
