Beko dcu 9330 R condenser dryer
Home Forums Public Support Forums Help And Support Tumble Dryer Help Forum Beko dcu 9330 R condenser dryer
  • #88050
    Imouttaluck
    Hi all. I’m in a bit of a bind. I have recently acquired a beko dcu 9330 R condenser dryer. It’s LCD had bled but could still be read. I had The dryer on and then suddenly it knocked itself off mid cycle and won’t come back on. The drum light still comes on so I know it’s got power going to it.
    The lint collector in the drum was bursting, the woman I got it off said she’d emptied it but I stupidly didn’t check!
    I’ve now emptied all lint, but the LCD/power won’t start the machine, rendering it dead apart from the drum light.
    Does it have a reset switch? If so where?
    I’ve tried unplugging it over night but still the same, I’ve changed the fuse just in case it was that but it’s not.
    Any help/advice, I would be very grateful for.
    Thank you in advance 🙂
    #436838
    Re: Beko dcu 9330 R condenser dryer
    have you checked the condenser is locked in
    there is a red tab that has a switch on it and if its not locked it wont start
    Imouttaluck
    Yeah everything is locked into place. I’ve went and plugged it back in tonight and it’s now come back on, I know there must be a fault somewhere but I don’t know what would cause it to just knock off and not come back on for days 🙁
    Nothing has changed over the last few days except me plugging it back in
