Beko DCU 9330W Door Open
  • #91009
    Payney
    Can anyone help. I have a beko dryer that is showing door open and won’t start. The door open symbol is lit on the display even though the door is shut and the internal light is off. The customer said that this had been working for about 25 mins then the light would come on but now the door light s on all the time so no start.
    Thanks in advance.
    Mark
    #446734
    kaibart
    Re: Beko DCU 9330W Door Open
    There is a small board in the dryer below main pub that I’ve had trouble with the internal light might be worth checking that 1st
    #446735
    Payney
    Thanks. The light itself seems fine. It seems that the door lock is working for the light to go out when the door is closed but the door open sign on the LED display is not going out and when start is pressed it beeps and won’t let the machine start. Could this still be linked to the PCB you mentioned?
    Mark
