Beko DCU7230 stops after a minute or so
Home Forums Public Support Forums Help And Support Tumble Dryer Help Forum Beko DCU7230 stops after a minute or so
Viewing 1 post (of 1 total)
  • #92806
    ChichesterCraig
    Hi, I have a Beko DCU 7230B that stopped working a few days ago.
    When I power it up everything appears to work fine, put some clothes in and hit start and it runs for about a minute then stops with the Drying and Cancel lights flashing very rapidly. At this point the machine no longer responds to any buttons.
    The drum turns and warms up in the short time before it stops. Switching the power off then back on allows it to restart but then after a minute it switches off again.
    I have tried it on different programmes, timed and sensor, and both do the same.
    I have run it in test mode; test mode starts normally, I press the start button once to spin the drum with no heat and it does the same. The drum stops and the Drying and Cancel lights are flashing rapidly and no other lights are shown. Again the machine is unresponsive until I power off.
    Any ideas?
