BEKO DCU7230 Tumble Dryer No Heat
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries BEKO DCU7230 Tumble Dryer No Heat
  • #88367
    Taff543489
    Went to this job today customer reported no heating. Checked the elements Cut out stat and Thermistor on the element good readings. Checked the thermistor on the front of the machine good resistance. Ant body have ideas before I condemn the control module? 🙁
    #437825
    wilf
    Re: BEKO DCU7230 Tumble Dryer No Heat
    double check the heater ntc if it’s outside limits up or down you’ll get no heat I hook on an old hotpoint washer ntc to check.
    wilf
    #437826
    Seamy
    You need to check the NTC is not down to earth, thats where they are problematic.
    It may read temp ok across the 2 tags, but you need to megger it to earth as they internally break down, a new style NTC is fitted on the updated heater now available. Worse case it will have taken out p.c. too.
