Beko DCU7230W Dryer
  • #81244
    link1980
    HI
    Ok so to start with I am a moron. plain and simple.
    The button panel on our beko dryer broke (the switch return part) simple enough and cheap enough to replace. Being a moron though i disconnected the On / off push switch to get to it and didn’t note down or photograph which colour wires went to which connection on the switch.
    I have tried what it think to be all of the possible ways but as soon a splug it in and press the on button it pops the fuse and the RCD.
    PLEASE does anyone know which bloody way round these wires go?!?!?!?
    #415919
    Re: Beko DCU7230W Dryer
    have looked at the tech info and they dont list colours or connections for this switch
    you need to find someone who can use a multimeter to buzz through the connections. once you find the pairs of connections that go together you can avoid putting the mains on the same side
    link1980
    so the feeds from the mains need to be on opposing sides? i can see that two wires come in off the mains brown (assume live) and orange. should these be on opposing sides then?
    #415921
    link1980
    Cheers Dave, looked at it again and put the mains wires to the bottom connections and the output wires ot the top connections and working perfect. Lesson learned always note the wires even if i think i can remember just 4 wires! thanks again Dave
    #415922
    no probs glad you sorted it and learned a valuable lesson
