Beko DCU8230
  • #83860
    ray.t
    Got one of these with no heat, checked the heater all ok, ntc ok but no power to the heater plug at the back of the cabinet.
    I have since changed the pcb thinking this would sort it but its still the same no power to the heater.
    Just wondered if anyone has had this before as I’ve got another one the same to look at on Tuesday.
    Cheers,
    Ray
    #423999
    Re: Beko DCU8230
    have sent you some tech info
    plus did you try it with wet clothes in it ?
    ray.t
    Re: Beko DCU8230
    Hi Dave,
    Thanks for the info, I will go back armed with that and see if I can sort it out.
    I did try it with wet clothes and also on the timed setting but still no heat.
    I hope I can sort it as these dryers seem to be getting popular round this way and searching through old posts it looks like its a common fault, just a pity no one has come up with a fix for it yet or if they have they haven’t posted up.
    Thanks again,
    Ray
    #424001
    Re: Beko DCU8230
    got a similar one at mo but yet to go round armed with Beko info
    going tomorrow so will see
    on mine i checked relays on board so i know its not a relay failure
    ray.t
    Re: Beko DCU8230
    Hi Dave, I don’t know if you have seen the other post about cleaning the sensor strips? I am going back tonight to try this and have another look over it.
    Cheers,
    Ray
    #424003
    ray.t
    Re: Beko DCU8230
    Just been back and its still not working.
    I have neutral at the heater plug but no live. Looking at the diagrams the live comes straight from the board but something is stopping it I just cant work out what.
    I hope you have better luck tomorrow!
    Cheers,
    Ray
    #424004
    Seamy
    Re: Beko DCU8230
    Check the NTC on heater they go down to earth anything below 2M will cause no heat fault, normally its because of the condenser not being clear, excess moisture forms on the element.
    New heater normally sorts it out.
    If you are really unlucky the shorted element may have taken out triac on board too.
    #424005
    ray.t
    Re: Beko DCU8230
    Hi Seamy,
    You’ve got me thinking now. I had both plugs unplugged from the heater plug when testing but now from what you are saying it needs the ntc plug connected before it will power up the heater?
    Thanks,
    Ray
    #424006
    Re: Beko DCU8230
    it will need ntc as board needs to sense it in case of failure
    my customer has already fitted a new heater before they called me
    Seamy
    Re: Beko DCU8230
    Heres a tip, if you think the dryer may have a duff NTC causing no heat fault, swap the leads off NTC on dryer heater onto a washing machine heater NTC, you will likely have a spare one lying about in van.
    The cable lugs are same size too.
    Let the NTC dangle & attach back plate of dryer with a few screws, run on test for minute to establish if it heats up.
    Then if it heats with test NTC in, order up a new heater as you can’t buy the Beko NTC separately. If it doesn’t it may be a P.C.B fault as heater faults sometimes blow boards too.
    :lesson: DO NOT LEAVE TEST NTC IN PLACE
    #424008
    Re: Beko DCU8230
    mine is different model DSC85w
    looked up on beko technical and there is a bulletin re the elements. they changed the thermisor old one is grey new one is white. according to sheet the 2 are not interchangeable as the main board is different in each case
    since my customer had got his own element and its the wrong one i cannot say for certain why his unit is not heating. played around swopping thermistors to hotpoint ones. linked old thermistor in circuit but not touching earth still no heat.
    in my case customer would need correct pcb and correct heater or maybe just correct heater.
    he is going to contact espares who obvoiusly dont know there are 2 elements and see if they will swop it
