Beko DCU8230
  • #87070
    Hollytree_Technical
    Hi All
    Industrial Code: 7189041200
    I have just had to change an element due to IR fault on the NTC but the dryer won’t heat.
    Can anyone tell me if there are any technical bulletins etc available on this machine, I am specifically wondering about the heating element and temperature sensors as I have found snippets that suggest there may be a sensor change which may or may not require a different PCB.
    Any other technical Info for this machine will be greatly appreciated.
    Thank you
    Jem
    #433879
    Seamy
    Re: Beko DCU8230
    Sometimes short circuit on the NTC of heating element takes out P.C.B so that may need replacing. New heaters now have better design of NTC, its not needed to change P.C.B just for new style heater, but as previously stated original faulty NTC may have taken out board.
