Beko dcu8230 condenser dryer
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Beko dcu8230 condenser dryer
  • #76938
    ddirect
    Intermittent fault sometimes it heats and dries,other times it just tumbles with no heat,can do this for a couple of days, then try it again and it starts to heat and dry?
    Just been today and given the two metal strips a clean (sensordry sensor)
    ps it also doesn’t heat on the timed dry ?
    Any help most appreciated
    Darren
    #400219
    Re: Beko dcu8230 condenser dryer
    Heater Relay stuck on PCB?
    #400220
    ddirect
    Ill bare that in mind Martin but as of yet after cleaning the sensor strips i haven’t had a call back. This machine does get a lot of use.
    Thanks for the input. Martin.
    #400221
    ray.t
    I have one of these with no heat but the customer did say it did work once after they first noticed it stopped heating.
    Can you tell me where the sensor strips are please.
    Cheers,
    Ray
    #400222
    ddirect
    Heater strips at the bottom just inside the door porthole stick your head in look down and you will se some raised metal strips
    Darren
    #400223
    ray.t
    Thanks, I will give it a try.
    Ray
