Beko DCU8230 Condenser dryer
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Beko DCU8230 Condenser dryer
  • #96366
    rocker
    There is a negative feed missing to activate the water pump..positive feed ok…rest of machine is working ok…hoping anyone with experience on this type of machine could help and confirm if it could be the Pcb !! ..if not is there any sensors /toc in line that may cause this fault…cheers John
    #463148
    the pump is fed off relay 3 on the board. could easily be that not working
    there is an overflow sw but cant find where it links into the circuit
    you need to check if the relay coil is being energised or just swop it
    rocker
    cheers Dave..john
