hi has anyone experience of fitting the small belt on these.. does the full drum have to come out to remove fan cover to slide over motor shaft ? thanks
if its the one Im thinking of it comes as a belt pulley kit. I thought to take the drum out but you can take the motor out (side panel off fan off) I took off more than I needed but the next will be much easier not too bad a job
