Beko dcu8230 Condensor dryer No heat
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Beko dcu8230 Condensor dryer No heat
  • #77192
    grooster
    I’ve been out to a Beko condensor dryer and the original fault was that it was tripping the mains.
    It turned out to be one of the thermostats on the heater had a short to earth.
    I’ve been to fit the element today, all was well, its not tripping but it just wont heat.
    I presume its done damage to the pcb, but i was just wondering if there is something simple that i’m missing.
    All help appreciated,
    Cheers
    Nick
    #401336
    Andy jones
    Re: Beko dcu8230 Condensor dryer No heat
    Sorry to state the obvious but is it being tested on timed drying not auto
    #401337
    grooster
    Sorry, should have mention that, tested in both timed and sensor dry.
    #401338
    Andy jones
    Yes thought so mate, assuming the new element is ok then it may well of damaged the board
    #401339
    grooster
    Yes, the new element seamed to read OK, but I was just getting live at all the connections coming to it. Thought it would be a pcb just never had to swap one as of yet.
    #401340
    Criscold
    Looking at circuit diagram the heater is switched via the board on the live and you should be getting a neutral feed from on/off switch and not via the board?
    #401341
    grooster
    Neutral from the on/off switch. Thats interesting, i’m going to have another look at it today and i’ll check that out.
    #401342
    dave-m
    Any fix on this, I’ve the same problem.
    Is there a relay on the board i could change?
    grooster
    Hi Dave,
    Never got to know the real outcome. I tested everything and just came to the conclusion that the pcb had blown when the stat shorted. The customer just wrote the machine off.
    Sorry
    Nick
    #401344
    dave-m
    No problem, thanks for the quick reply.
    I might try and change a relay and see how i go.
    I’ll let you know the outcome
    Regards
