Beko dcu8230 water tank full
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Beko dcu8230 water tank full
  • #85731
    jon90
    Hi guys currently working on a beko dcu8230 condenser tumble dryer. After 10-15 mins of drying the dryer stops and water tank light flashes, when restarted it will run for a few minutes and stops again. Have checked pump is working and pumping up to container. No blockages in pipework and cleaned condenser unit. Have changed front ntc as ref to another post also cleaned the dampness sensor bars . Any help with this problem would be great fully appreciated. Regards jon
    #429416
    aqualectric
    Re: Beko dcu8230 water tank full
    You need to clean out the float chamber that signals the “Tank full” light. That should be joined to the area the condensate pump is fitted to. Seem to recall it is accessed from the rear panel. (loads of screws!!)
    HTH,
    Steve.
