Hi guys, above dryer runs for about 3-4 mins then machine cuts out including display. After a few minutes the display will come back on and machine can be restarted. Anyone come across this before? Is it just the consul PCB at fault?
from picture of board the power supply is the collection of components on the pic. look for bulging caps on the low voltage side ( small caps on right ) or you could try changing power supply chip the small chip in middle ( cant see if a 7 or 8 leg version) they are very cheap
