Beko DE 3542 FS – Low Jet Pressure
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Beko DE 3542 FS – Low Jet Pressure
Viewing 16 post (of 16 total)
  • #378332
    Russ h
    Re: Beko DE 3542 FS – Low Jet Pressure
    OK, are you ready for the fault……I can hear the laughs already!!
    I had the unit raise on a bench so I could check pumps ect during operation. What I had completely forgot to do is raise the waste pipe. above the internal water level, so as it was filling up, the water was simply escaping straight out the outlet pipe!!!
    Hence the pump never having enough water to pump!!
    So with the new cap fitted, and the waste pipe at correct height…..it now works a treat 🙂
