Home › Forums › Public Support Forums › Help And Support › Dishwasher Help Forum › Beko DE2542F Dishwasher Fault
- This topic has 7 replies, 5 voices, and was last updated 14 years, 10 months ago by
prob70.
June 4, 2011 at 8:27 pm #63182
prob70
ParticipantHi, I have a Beko DE2542 Dishwasher that has suddenly stopped working. I turn the Dishwasher on as normal, I press start and the green WASH light comes on but nothing happens no matter how long you wait. If I press and hold the START/CANCEL button for 3 seconds the WASH and DRY green lights will flash on/off at the same time. I have also unplugged the dishwasher for an hour to reset everything but no use. Whatever I do, I cannot get the dishwasher to start.
There is absolutely nothing in the faults section of the manual describing this fault. The dishwasher is about 1 month old and I know will be covered under warrenty but I am thinking along the lines that it is something silly we are not doing or doing. Any Ideas would be appreciated?June 4, 2011 at 9:33 pm #352890Applianceman2010
ParticipantRe: Beko DE2542F Dishwasher Fault
In all honesty it could be a number of different things, door switch,outlet pump or PCB 😐
June 4, 2011 at 10:05 pm #352891prob70
Ah thankyou anyway. I thought there maybe a sequence of buttons top press or something to correct it.
June 4, 2011 at 10:14 pm #352892Applianceman2010
It maybe worth getting an engineer out to have a look at it . As its a washer/Dryer its prob worth a look at….
August 17, 2014 at 2:05 pm #352893Total amateur
The same thing happened to me -exactly the same symptoms – and I was able to resolve it by emptying water that had got into the base of the machine. This was achieved by first tipping the machine on it’s back and then putting it on it’s front with a number of towels in close attendance. I was very surprised to find that this did the trick. The question is why did this happen and how can I avoid it happening again?
August 17, 2014 at 6:46 pm #352894lee8
Stick your ear on the cabinet, lower the better, if you hear a faint humming noise when you press start button it will likely be the drain pump jammed by glass/debris etc.
August 17, 2014 at 9:15 pm #352895iadom
ModeratorRe: Beko DE2542F Dishwasher Fault
Applianceman2010 wrote:It maybe worth getting an engineer out to have a look at it . As its a washer/Dryer its prob worth a look at….
Pardon? :con:August 18, 2014 at 11:31 am #352896lee8
Wasn’t sure either if he meant a blow dry dishwasher or a washer/dryer.
