Beko DE2542FW tripping mains
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Beko DE2542FW tripping mains
  • #76777
    BarkbyThorpe
    Everytime this machine is powered ON, it lights up on the front. As soon as the START/STOP button is pressed it trips out the main house circuit immediately
    Ive disconnected and removed the heating element and this stops the tripping. However, a resistance check across the terminals measures 25/30 ohms, which for a 230v/1800w element is correct using ohms law? Have I missed something? Are there other known faults for this problem? Could it be the motor?
    Any help much appreciated
    Many thanks
    Regards
    mick
    #399819
    Andy jones
    Re: Beko DE2542FW tripping mains
    You need to do an insulation test on the element
    #399820
    Seamy
    BarkbyThorpe wrote:Hi
    mick
    As my learned friend said do an insulation test on the element & you may find theres an earth fault on it.
