Beko din15x10 not washing.
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Beko din15x10 not washing.
  • #98007
    Njwwright
    This-morning I discovers out beko dishwasher hadn’t cleaned anything in its nightly run. It fills with water no problem, drains no problem. The recirculating pimp pumps away and vibrates but nothing comes out of any of the sprayers. If it take the bottom spray arm off then I can see the water pumping about 10mm up out of the pipe but that’s it, there’s just no pressure or volume behind it and the pump just pulses away rather than a fast constant flow. I’ve removed the pump and piping/heater and there are no blockages within the circuit of water being pumped out of the bottom of the dishwasher, all the way through the heater, pump and then back into the dishwasher. I suspect the pump is at fault but before paying £75 for a new pump I wanted to check if anything else would prevent the pump from creating any significant flow.
    #470542
    could be blocked / jammed
    could be a faulty pump
    could be a faulty board
    there are sellers on ebay with great feedbacks selling these motors for £55
    Njwwright
    Hi Dave, thanks for the reply. I can’t find any blockage along the route so I’m reasonably confident it’s not that. If it was a faulty board, would I see an error – if my dishwasher is capable of showing one? I’ve found the pump for £65 on eBay, will see if I can find it for £55.
    #470544
    Njwwright
    Yes that looks right, thanks Dave!
    #470546
    Njwwright
    Out of interest do you know how to run a test cycle on my dishwasher. All info I can find says to hold down the mode selector button and start button for 3 seconds my my dishwasher doesn’t have a start button. If starts automatically when I close the door after selecting the right mode. It has a power button, mode selector button (p), half load button, extra power spray button and a timer button
    #470547
    its a bit more difficult than that you hold on off and programme button to get in sevice menu
    then you need to set programme 3
    then if it stop while executing press the delay button
    Njwwright
    Thanks Dave. Sorry I didn’t understand you last sentence. Hold down power and program button for three seconds. Then select mode 3 with the program button, then close the door and it will run the test cycle? Then if it seems to stop press the timer delay button to make it carry on with the testing? How will it show up any errors?
    #470549
    p1 to p6 will blink
    Njwwright
    Ok thanks, I’ve run the test and no errors have come up. The circulation pump sounds relatively normal, you can hear the sound of water flowing through, if you open the door water is just coming out of the top of the sprayer tube (spray arm removed) and just sort of glugs up and down at a rhythmic of about once every one or two seconds. If I put the spray arm back on there isn’t even enough pressure to fill the arm up and water to trickle out of it.
    How deep should the machine fill with water, it covers the whole base by a few mm in depth, that seems plenty enough for the pump to use but could it be a filling float level issue? I did try pouring more water in but that made no difference to the water coming up the spray pipe. I presume it should be coming out of the pipe at quite a force normally?
    #470551
    your right that pump is not running at anthing like full power
