Beko DIS16R10 Won’t Start
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Beko DIS16R10 Won’t Start
  • #101158
    kjhb
    Hi all,
    My Beko DIS16R10 is refusing to start. There’s no water pooled in the bottom and I’ve rinsed the sensor below the filters in case it was that.
    The switches are capacitive touch and I’m not certain the start/stop button is registering input.
    The user manual allows for water hardening adjustment using a combination of keys + the start button and this won’t work, so perhaps it isn’t working.
    I’ve tried holding it down for 3/7/10 seconds, unplugging for a minute, with no obvious reset taking place.
    I’ve attached a video so you can see this happening.
    If anyone knows what I should clean/replace it would be greatly appreciated. Thanks
    [video]https://www.veed.io/view/dd84ff3b-21ed-4150-8f3d-1fd0194a4344?sharingWidget=true[/video]
    #483615
    you would have to strip it and see
    it may not be touch buttons but small tactile switches
    if you remove the panel and check. there seems to be an electronic panel underneath where the switches are
    look for water damage, bad connections etc
    kjhb
    They’re definitely touch on this model at least, PCB inside looks absolutely fine, it’s so tiny there’s no chance I can test the pins for the start switch to see if it’s registering.
    I can’t imagine it’s an insanely expensive part but no website seems to just sell the buttons for this one.
    https://i.imgur.com/0ep1xf9.jpg
    #483617
    if the panel has failed then looks like touch circuit comes with the top panel
    got part no but no one has sold one anywhere
    you can check the loom as its not uncommon to break wires as they leave the bottom of the door
    kjhb
    I’ll check that, thank you
