Beko dishwasher
  • #96349
    Jazzyntv
    I have a Beko Dsfn 1530 b dishwasher once it has finished a cycle after a couple of days the water level keeps increasing very slowly! Could this mean that the water inlet solenoid needs replacing or something else? Thanks Michael
    #463101
    water can only come in 2 ways
    either a) through the inlet solenoid
    and b) through the drain hose
    if its A then yes inlet valve needs replacing as its acting like a dripping tap
    if its B then every time you use your sink a little bit of dirty water goes into the dishwasher. if this is the case its just a matter of re routing the pipes draining the dishwasher so they come in higher to stop the water flowing back
    try turning off the tap to the dishwasher and see if it stops filling
