I am having an issue with my Beko Dishwasher and I wondered if any of the learned members of this forum can suggest a solution.
Model DIN28R22
Age : 3 years
Problem
We tend to set the cycle running overnight so timings may not correct but basically we set the programme running and initially all appears to be working ok. Then next morning I find, on opening the dishwasher door, the drain cycle hadn’t happened.
As I said earlier because it was running overnight, I am unclear if it was the first or subsequent drain cycle.
On looking at the control panel, all the lights are off suggesting the unit has been switched off.
If I switch the unit back on, the display shows a remaining time to cycle and closing the door commences the programme.
This then runs to completion.
If I knew the timings of the different operations within a cycle i.e. fill, drain, dry etc, I could from seeing the remaining time, see which cycle change triggered the machine switching itself off. Trouble is you cannot see what’s going on behind the door.
Any thoughts or further diagnostic suggestions would be appreciated
Les Wilcock
