BEKO dishwasher
  • #102853
    dunston
    Beko dishwasher, model DIN28R22. PROD NO 7648153877. The dishwasher fills, no wash motor action, not heating. the detergent dispenser flap opens. the display times down as normal. the machine also drains ok. I have checked the wiring harness in the door. this is an inverter type machine. anyone had problems with the heat pumps on these or the main board? is there a diagnostic that can be ran as no error codes show.
    thanks Mark
    #490776
    had one the other day
    the motor did run a bit and made a weird noise
    it never ran again
    took hose off and lots of play in the motor shaft
    only place i could find a motor in stock was ASWO also listed but not in stock was a bearing kit for the motor. 3 to 5 week order time so wont be a quick job to try it
    mine was 3 years old
    dunston
    Cheers Dave. we thought it may be the heat pump or the main PCB. Will look into that.
    Mark
