beko dishwasher
  • #25753
    fasetester
    hello any one have this problum before beko dishwasher model D3422fw stoped at between 3 and 4 on program engineer looked at it awhile back and said it was air locked await reply thanks. 🙁
    #207451
    Re: beko dishwasher
    Moved from public forums to TRADE side, you been on the loopy juice tonight fasetester 😀
    #207452
    fasetester
    Re: beko dishwasher
    dont bother with loopy juice what about some info on the dishwasher repair on the beko d3422fw are they prone to any fault where the program stops at 3 and 4 and what would cause an air lock a blockage some where and then i will have some electric soup that should liveing thing up a bit zzzzzzz zzzzzzzz fasetester 😆
    #207453
    Re: beko dishwasher
    I don’t see a lot of these, Fase. There are two regular problems – the seal in the pump fails and floods the base – flood protection system can run the drain pump for hours whilst not advancing the timer.
    I’ve had a few NTC failures as well, but the programme will usually clunk round to the end after the allowed heat period.
    fasetester
    thanks chris for your reply the the man said it happened before and the engineer done something inside that cured it he said it was air locked can you get at the pump from inside when you take out the filter are the prone to any pipes blocking up the pump you are talking about chris is it the main wash pump that the seal leaks or the empying pump are the 2 seperate pumps is there any way to test the ntc if the are faulty does the case crack on them or any burn marks can the be tested with a meter do you go in from the front or under neath thanks fasetester.
    #207455
    fasetester
    Re: beko dishwasher
    well guys any beko experts with any more help that can add to what chris has said have to go and check it out tomorrow are the prone to air locks and blockages the dishwasher was left on all night and in the morning it had stopped at 3 and 4 on the program thanks fasetester 🙁
    #207456
    robbra
    Re: beko dishwasher
    Have a look underneath, the base comes off and everything is get at able????? NTC is a tiny stat clipped to the base of the tub but never had one fail. The drain pump is a sealed Plaset type but the cycling pump shaft seals often leak. I have also found that the softener is not always securely tightened to the tub and also the same for the matrix on the side.
    Hope that’s enough to be going on with.
    Rob
    #207457
    fasetester
    Re: beko dishwasher
    thanks robbra for your reply would the softner or the martix being loose cause a air lock when i went to look at the dishwasher it was going ok the woman said the last time it done that the engineer was working at something on the side of it and said the were prone to air locks is that true can the seal be changed on the main washer pump. fasetester 😕
    #207458
    robbra
    Re: beko dishwasher
    Have had 2 airlocks in the matrix and have just emptied it and never been back.
    I have never had to just change the pump seal, have always changed complete pump as on other makes the seal can waer the shaft and I would imagine the pump bearings are on the way out too because of the leak, if it is from there. Easy to remove the pump, 5 minutes and check. Not worth the risk if it is.
    Rob
    PS Pump around £54 + from connect
    #207459
    fasetester
    Re: beko dishwasher
    thanks again robbra for the info dont know what it was its going all right for now when left on all night checked it in the morning had stopped at 3 and 4 on the program dont think the should be left on all night with every one in bed 🙂 fasetester
