Beko Dishwasher 3431 FW
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Beko Dishwasher 3431 FW
  • #35898
    spangu
    Diswasher will not stop.
    Water has drained.
    Completed a wash cycle and unit is still making noise(possibly pump), it will stop if I turn off at main switch or open door, but start stop button makes no difference.
    Where would I start to troubleshoot or is there a way to reset?
    I have tried unplugging the unit and this did not help.
    Changing cycle selection knob wont help either.
    If i hold in start/stop button it begins to blink.
    #248590
    Re: Beko Dishwasher 3431 FW
    Flood protection activated. Tray under machine is full of water and has tripped a float switch. Lean machine to the left to drain (with the power off) and re-set. If you get a repetition, you must find the leak.
    In my experience, the circulation pump is the usual culprit.
