Beko Dishwasher DFN28J20X – not heating up
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Beko Dishwasher DFN28J20X – not heating up
  • #97116
    drewbeaton
    Our dishwasher has started heating up. It seems to run as normal. I can hear the water rinsing the dishes & it’s draining fine.
    However, the dishes are wet & there was significant grease build up in the drain. After running drain cycles, I’ve just noticed that it does not appear to heat up.
    Whats the most likely fault? Heating element, thermostat? If so, are they fairly easy to access for an enthusiastic amateur? Are the parts easy to obtain?
    Thanks in advance for all advice and help offered.
    #466188
    it is most likely the heater but you would have to check
    access is not too bad from front and taking off bottom tray
    heater is on right hand side on the hose leading to the wash motor
    https://shop.ukwhitegoods.co.uk/hs81596-compatible-dishwasher-heating-element
    effectively 2 hoses with clips and 3 wires
    drewbeaton
    Thanks – I’ll take it off and test it.
    #466190
    drewbeaton
    electrofix wrote:it is most likely the heater but you would have to check
    Fixed. Thanks for your help.
