This machine empties fine to start but then goes totally silent, doesn’t fill, click or make any other sounds…… press cancel, it’ll pump out ok
CX says either F1 or F2 shows up but neither did for me while on visit……. I’ve read some posts that say “fill valve faulty” but as the machine goes silent after pumping out, my thoughts were towards the pcb — ANY ideas please?
With all the Beko dishwashers you need to check for broken wires in the door loom – I did a similar machine today with the same fault symptoms that turned out to be broken wires in the door hinge.
