Trips out the mains when plugging in, megger shows short to earth. You would think this would be easy but after disconnecting everything one by one starting with element and motor the short is still there. Have checked wires in the lower door area and they look ok but then this dishwasher is only just over one year.
Any ideas?
Yes it has water gets in the neon some are available with just the loom fir neon some are complete harness just cut the wires to neon you have nothing to loose as you can remake wires
Many thanks for your help, it just turns out a came across another one of these today that was tripping out as soon as its plugged in so I went straight to the neon light and you are right. Thank you for your help again.
