hi, hope you can help.
A few days our dishwasher has stopped filling. When I start the cycle, it starts to empty and then it should fill. I immediately thought it was the inlet valve which I replaced anyway with a new one. This did not fix the problem.
The float switch is on the bottom tray which was dry. I have checked the the float switch and there does seem to be a change in ohms when I use a multimeter when I depress the switch which seems like it is not faulty either.
I have tried to empty as much of the water out of the salt dispenser just incase.
I am out of ideas so any help is appreciated.
Not sure if this is relevant but the salt light on the front panel is not red anymore. I don’t use salt, never have, as I use all in one tablets.
Please help
Jason
