Flagging this one up because machine was only 1 .4 years old so you`d not expect the following: no wash motor action and no hum or any other noise other than it fills and can pump out.It`s not the motor but I had 4 wires break in the door wiring loom one of which was a motor wire! The protection sleave was, errr not protecting because the factory had not tucked it under the curve of the tank and so wires stuck to the tar and so broke with the opening of the door. Hope this helps someone else.
