Beko Dishwasher DWD8657W no heat
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Beko Dishwasher DWD8657W no heat
  • #58232
    bubs
    Have this dishwasher not heating at all, no error messages.
    The “tube” type heater measures fine, i have changed the sugarcube relay on the pcb, still no heat. The temperature probe measures 64k with cold water in it. No idea if this is correct.
    Anyone had similar?
    Thanks for any advice.
    Graeme
    #333806
    Re: Beko Dishwasher DWD8657W no heat
    only value i can find for ntc is 17K at 50 degrees
    looked through tech data but not much help
    can let you have test prog info etc if you want
    bubs
    Thanks mate.
    If customer ok will order a pcb, cheap enough.
    The ntc value sounds about right.
    will update if i go back.
