Beko Dishwasher fault
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Beko Dishwasher fault
  • #95547
    Mullberry
    I have a 18month old Beko ProSmart inverter DFN26220X dishwasher, it recently stopped fuctioning and displayed E01 on the display. information i found suggested it had overflowed and was trying to constantly pump out the water. i disconnected the machine and found water in the lower tray, dried this out and reinstalled the machine. It then continued to fill to a point of overflowing whilst showing error 02. the unit was sent to an official Beko repair center (here in Bulgaria) and was returned 3 weeks later as no problems or errors found. i reinstalled the unit and it worked fine for 1 week. it is now showing error 01 again and constantly trying to pump out water allthough nothing is exiting the drain pipe. after removing and re attaching the power supply the machine pump just starts again with error 01 showing .. Any advice, help, suggestions please
    #460707
    well you could check the pump for obstructions but cant get tech on this one as we are in the UK
    Mullberry
    Pump appears to be working fine, added water manually and it pumped out as normal, think i;ll pull the side panels off and check the flood switch and float (if thats what they are called), a couple of other sites suggest that may be an issue.
    #460709
    yes could be the microswitch may have jammed in the flood position or burnt out (seen a few)
