I need to dismantle the circulation motor & pump but can’t get the chassis-mounting bracket off the motor end-frame. It’s held on with a screw securing a white nylon bush/ring in the endframe. I’ve removed the screw, but the ring, which looks as if it should just pull off once the screw’s removed, doesn’t. Am I missing something or should I be pulling harder?
Geoff
Couldn’t you have replied a bit quicker? Customer’s without her dishwasher.
Seriously though folks, I take it that that reply indicates that from your experience it’s not feasible to dismantle the motor and a replacement is necessary.
