Beko dishwasher stopping mid cycle.
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Beko dishwasher stopping mid cycle.
  • #88267
    Markgodley
    I bought a beko dishwasher (model DWD5414W_WH)about 2 years ago.
    About 2 months ago it kept stopping mid cycle (sounds like it does the collect water part, then sounds like it’s spraying for a few minutes then stops). I read online about a 45degrees fix which clears a build up of water which actives a flood sensor (likely means I have a small leak somewhere), this worked until about 10 days ago.
    Tried the above fix again but no water coming out this time but same symptoms as before.
    It’s not a blockage as I’ve poured water in and cancelled the cycle, which then empties the dishwasher.
    Anyone offer any advice before I look at getting a replacement. There seems to be little to non diagrams of the dishwasher online, so not sure what to look for to check the flood switch. Any help is appreciated.
    #437529
    Seamy
    Re: Beko dishwasher stopping mid cycle.
    water may have flooded base, base is below dishwasher cavity
