I’ve had a fault where a Beko DFN05X11W dishwasher was continuing to pump after the programme had finished. On inspection, there was water in the bottom and the anti flood switch had kicked in. The water was coming from the sump.
I renewed the gasket with a genuine part, but it seems the problem hasn’t been resolved and there’s water still leaking from between the sump and the base of the machine.
Already done that. The sump’s been off a couple of times now. Checked the gasket and applied a very thin layer of rubber grease. Double checked everything yesterday but haven’t used the machine since, but not optimistic.
