Beko DL1243W – ‘pump’ continuos running
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Beko DL1243W – ‘pump’ continuos running
  • #83144
    Notretta
    I have a Beko DL1243W that stopped during a wash cycle (wash led light on) – it left the machine full of water. Tried to cancel the program by pressing the start/stop button for more than 3 seconds but it failed to respond. Powered the machine off and then back on and a ‘pump’ started up (the start/stop button had not been touched) leaving it to run it did not drain the water but stopped after about 5 mins. This happens every time the machine is switched on, the only led light on is the power light. Pressing the start/stop button does not appear to do anything at all.
    I have looked for an error code but have not been able to find any info for this on the net, so I am unable to provide any.
    I have drained the machine manually and checked the filter, and spray arms etc – all ok.
    Any ideas.
    Cheers, Nigel
    #421847
    Seamy
    Re: Beko DL1243W – ‘pump’ continuos running
    Nigel, sounds like there has been an overspill of water or leak into the base of appliance activating the float switch which will run pump continuously. Perhaps theres a blockage in pump or drain hose etc.
    Power off if doing any investigating
    #421848
    Notretta
    Cheers Seamy,
    Found water in the machine base, now to find the cause.
    Nigel
    #421849
    Notretta
    Impeller has come of spindle on drain pump 😮
    Regards
    Nigel
